Key Fob
Functions overview
The Key Fob lets you arm the system in "At Home" or "Away" mode, disarm it, and send a panic signal.
  • Inactive:
    No sensors in your home are active when you press this button. If an alarm has been triggered, it will be deactivated when you press this button.
  • Away:
    When you press the Away button, all sensors are activated. If one is triggered, the alarm goes off – ideal when you leave the house.
  • At Home:
    Press this button when you are at home and only want certain sensors to be active. You can select which sensors remain active in the app.
  • SOS button:
    Press and hold for 3 seconds to send a panic signal (works in any mode).
    Once triggered, the panic alarm cannot be stopped by pressing the disarm button on the Key Fob.
  • Blue LED indictaor:
Important notes
The battery is already inserted in the Key Fob and ready to use.
Add Key Fob
You can connect the Key Fob in your Home Security Set via the app or manually.
1. Via app
Follow the step-by-step instructions in the app to add your Key Fob.
2. Manually
  • Put the Base Station into pairing/learning mode by pressing and holding the reset/learn button on the back of the base station for 6 seconds. The LED on the base station will flash blue to indicate that it is in pairing/learning mode.
  • Press the Inactive button on the Key Fob. The blue LED will light up.
  • When the Key Fob has been successfully added, you will hear a single beep from the base station.
Change of battery
  • The Key Fob is powered by a CR2032 3V lithium battery.
  • When the battery is low, a message appears in the app.
  • Open the back counterclockwise.
  • Insert the battery with the positive side facing up.
  • Close clockwise.
Arming modes
Active (Away), At Home, Inactive
Alarm type
Panic
Power source
3V, CR2032 Lithium battery x 1
Battery life
3 years (actual battery life may vary depending on settings, the environment and usage)
Low-battery threshold
2.1 V
RF frequency
868 MHz
Range
300m in open area
Operating temperature
–10 °C to +45 °C
Operating humidity
85% relative humidity @ 23°C (non-condensing)
Dimensions
Ø44 x 12.7 mm (strap excluded)
129.2 x 44 x 12.7 mm (strap included)
Weight
15 g (battery excluded)
