Motion Detector
Function overview
Detects infrared signatures to identify movement in the protected area and signals the base station to trigger an alarm
Typical detection range: Up to 12 m at mounting height 2.4 m
Pet immunity: Ignores pets up to 25 kg
Two-part design: Cover (electronics & optics) and base (mounting)
LED indicator
Lights for two seconds for motion detection when battery is low or button is pressed (battery low).
No LED indication with normal battery level (except in Test mode)
Battery
Uses 2 × 1.5 V AA alkaline batteries (pre-installed, with insulator)
Low battery → app message + optional push notification, call, SMS, email
Battery replacement:
Remove old batteries
Wait 10 minutes
Press LED button twice (discharge batteries)
Insert new batteries
Supervision
The Motion Detector sends monitoring signal periodically
If signal not received → “Accessory Failure” in app + optional push notification
Sleep timer
Once motion detection activated, enters ~one-minute sleep mode (no signals).
Further motion within this period adds one further minute, up to three min. max.
Pet immunity (Jumper JP3)
ON = Pet immunity disabled
OFF (default) = Pet immunity enabled (ignores pets of up to 25 kg)
Sensitivity adjustment (Jumper JP4)
ON (default) = increased sensitivity
OFF = normal sensitivity
Remove the battery-isolation strip to switch on the detector.
Follow the instructions in the app to add the Motion Detector.
Put Base Station in pairing mode (press Reset/Learn for six seconds until LED flashes blue).
Press and hold LED indicator on detector for three seconds (LED lights up).
Success = one beep from base station. If the detector has not been added within 25 seconds, please repeat the pairing process.
Tip:
Give each detector a uniquely name for easy identification.
Mount on flat wall or in corner → widest coverage
Keep field of view clear (no curtains, furniture, etc.)
Recommended mounting height: 2.4 m
Higher mounting = larger pet-immune zone, but bigger blind spot below
Choose a location to which animals cannot climb.
Do not aim the device at staircases.
The objective is that intruders should move sideways across the field of view.
Mounting:
With screws and wall plugs
Alternatively, with double-sided adhesive pads (included)
Limitations
Not for outdoor use
Avoid having large obstacles in detection area
Avoid direct sunlight
Avoid damp or condensatiuon-prone areas
Avoid moving objects (e.g., curtains)
Avoid reflective surfaces (e.g., mirrors, windows)
Do not install near AC/heaters
Avoid reflected IR signals (may cause false alarms)
Test the detector by walking past it. Check whether you receive a notification on your mobile phone.
| Setting from device | Sensitivity / Pet immunity (by internal Jumper setting) |
| Button functions | Test button, Learn button |
| Pet immunity | Up to 25 kilograms |
| Sleep timer | 1 minute, extendable up to 3 minutes maximum |
| PIR motion sensor | Range 12 metres |
| Horizontal angle | 90° |
| Vertical angle | 52° |
| Installation height | 2.4 metres |
| Power source | 1.5 V, 2 AA alkaline batteries |
| Battery life | 3 years (actual battery life may vary depending on settings, the environment and usage) |
| Low battery threshold | 2.65 V |
| RF frequency | 868 MHz |
| Wireless range | 300 metres in open space |
| Operating temperature | −10°C to 45°C (14°F to 113°F) |
| Operating humidity | Up to 85% (non-condensing @ 23°C) |
| Dimensions | 75 x 75 x 43.5 mm |
| Weight | 77 g (battery excluded) |
