Smart Plug
Function overview
The Smart Plug allows you remotely to switch connected appliances/devices on or off.
By integrating it into smart routines, you can conveniently control appliances – enhancing comfort and energy efficiency.
Once paired with the base station, the Smart Plug can be controlled remotely or automatically via the app through schedules and smart routines.
LED indicator overview
"ON" after three flashes: Smart Plug is turned on
"OFF" after three flashes: Smart Plug is turned off
Flashes twice: Switched on
Flashes slowly: Pairing/learning mode
Flashes three times: Learning successful
Brief flash: RF signal transmission
Button usage:
Press once: Toggle smart plug "ON"/"OFF"
Press and hold for three seconds: Pairing/learning mode
Press and hold while switching on; release when LED lights up: Factory reset
Plug the Smart Plug into the power socket.
Plug the appliance into the Smart Plug (appliance must be turned on).
Maximum load
230 V, max. 3680 W / 16 A
If overheating occurs, the Smart Plug cuts power off automatically (LED flashes rapidly) and resumes once temperature drops.
Follow the instructions in the app to add the Smart Plug.
Put the base station into pairing/learning mode (press Reset/Learn button for six seconds, LED flashes blue).
Press the LED button on the Smart Plug → LED flashes slowly (pairing mode).
Once paired, the LED flashes three times and goes dark.
Check that the Smart Plug works properly in the chosen location.
Tip
Give each smart plug a unique name for easy identification.
| Power source | 110–230 V AC, 50–60 Hz |
| Power consumption | 0.4 W |
| Maximum load | 110V: 1760W 16A 230V: 3680W 16A |
| Frequency | 868 MHz |
| Protocol | Climax |
| Operating temperature | –10°C to +45°C |
| Operating humidity | 85% relative humidity @ 23°C (non-condensing) |
| Dimensions | 73.6 × 46.1 × 82 mm |
| Weight | 99 g |
