  • Rewards Icon
    Keypad
    Function overview
    • Power saving feature — When the Keypad is idle, it enters power-saving mode, turning off all status LEDs and the backlight.
    • System status indication — The Keypad “wakes up” for five seconds when motion is detected or any button is pressed, displaying the System mode LED (Active: red / At Home: blue / Inactive: green) and all the buttons backlit.
      If there is no activity or motion detection for five seconds, the keypad turns off all LEDs and returns to power-saving mode.
    • Enter Away mode — Enter the PIN of any of the residents and press the key. If there are no faults and activation is successful, the Keypad will emit a long beep.
    • Enter At Home mode — Enter the PIN of any of the residents and press the  key. If there are no faults and activation is successful, the Keypad will emit a long beep.
    • Return to Inactive mode — Enter the PIN of any of the residents and press the  key. If deactivation is successful, the keypad will emit two beeps.
      • Entry/exit sound
        The Keypad will beep repeatedly when the Entry/Exit timer is activated (max. three minutes).
      • Force arm
        If a system fault is present when activating Active or Home modes, the keypad will emit three beeps. The user can repeat the activation action within 30 seconds to force arm.
      • Alarm memory
        If an alarm was triggered in your absence and the system not deactivated before the alarm stopped, the Keypad will emit three beeps when the system is then deactivated to alert the user that an alarm has been triggered while they were out. This indicates that the intruder may still be on the premises.
    • Panic alarm — Press the “SOS” button for two seconds. A long beep will sound and an alarm message will be sent.
    • Fire alarm — Press & hold the “4” and “6” keys at the same time for two seconds. A long beep will sound and an alarm message will be sent.
    • Learn signal — Press & hold the “*” and “#” keys at the same time for two seconds. A long beep will sound.
    • A short beep confirms each valid key press.
    • Five beeps indicate an incorrect PIN code or invalid operation (e.g., sending a home arming request when the system is armed).
    Installation
    1
    Activate the batteries
    Pull out the battery insulator to activate the batteries.
    2
    Add the Keypad via app
    Follow the instructions in the app to add the Keypad.
    3
    Alternatively: Add the Keypad manually
    3.1 Press and hold the Reset/Learn button on the back of the Base Station for six seconds.
    → The LED on the Base Station will flash green, indicating it has entered learning/test mode.
    3.2 Press and hold the “*” and “#” keys on the Keypad at the same time for two seconds.
    → The Keypad will emit a long beep.
    3.3 Connection feedback:
    • One beep from the Base Station: Keypad has been detected.
    • Two beeps from the Keypad: Connection was successful.
    • Four beeps from the Keypad: Connection has failed.
    4
    Perform signal-range test ("Walk Test")
    4.1 If the LED on the Base Station is no longer flashing green, re-enter learning/test mode.
    → Press the Reset/Learn button again for 6 seconds.
    4.2 Hold the Keypad in the desired position.
    Press and hold the “↑” and “#” keys at the same time for two seconds.
    → The Base Station will emit two beeps if the location is within signal range.
    5
    Mounting
    Once you've confirmed that the Keypad works reliably in the chosen location, proceed with mounting it.
    Congratulations! The installation of your Keypad is complete.
    Important notes
    If more than one Keypad is to be used, please assign a unique name to each device so it can be easily identified in alarm or system messages.
    Screw Mounting Instructions
    1. Rotate the front cover counterclockwise and detach it from the back cover.
    2. Break through the three pre-punched holes on the back cover.
    3. Using the 3 mounting holes as a template, mark the screw positions in the most appropriate place.
    4. Insert the wall plugs into the marked holes.
    5. Screw the back cover onto the wall.
    6. Reconnect the front cover to the back cover.
    7. Rotate the front cover clockwise to the Lock position as shown above (step 5).
    Change of battery
    2. Take out the old batteries, press any of the buttons a few times and place the new batteries in the battery compartments.
    3. Reconnect the front cover to the back cover.
    4. Rotate the front cover clockwise to the lock position.
    Arming modes
    Active (Away), At Home, Inactive
    Alarm type
    Panic
    Status LED
    Red (Active/Away), blue (At Home), green (Inactive)
    Built-in PIR sensor
    For power-saving feature
    Power source
    1.5 V AAA alkaline battery x 2
    Battery life
    3 years (actual battery life may vary depending on settings, the environment and usage)
    Low-battery threshold
    2.4 V
    RF frequency
    868 MHz
    Range
    300m in open area
    Operating temperature
    –10 °C to +45 °C
    Operating humidity
    85% relative humidity @ 23°C (non-condensing)
    Dimensions
    Ø113.5 x 19.5 mm
    Weight
    131 g (battery excluded)
