  • Rewards Icon
    Motion Detector
    Function overview
    • Detects infrared signatures to identify movement in the protected area and signals the base station to trigger an alarm
    • Typical detection range: Up to 12 m at mounting height 2.4 m
    • Pet immunity: Ignores pets up to 25 kg
    • Two-part design: Cover (electronics & optics) and base (mounting)
    • LED indicator
      • Lights for two seconds for motion detection when battery is low or button is pressed (battery low).
      • No LED indication with normal battery level (except in Test mode)
    • Battery
      • Uses 2 × 1.5 V AA alkaline batteries (pre-installed, with insulator)
      • Low battery → app message + optional push notification, call, SMS, email
      • Battery replacement:
        • Remove old batteries
        • Wait 10 minutes
        • Press LED button twice (discharge batteries)
        • Insert new batteries
    • Supervision
      • The Motion Detector sends monitoring signal periodically
      • If signal not received → “Accessory Failure” in app + optional push notification
    • Sleep timer
      • Once motion detection activated, enters ~one-minute sleep mode (no signals).
      • Further motion within this period adds one further minute, up to three min. max.
    • Pet immunity (Jumper JP3)
      • ON = Pet immunity disabled
      • OFF (default) = Pet immunity enabled (ignores pets of up to 25 kg)
    • Sensitivity adjustment (Jumper JP4)
      • ON (default) = increased sensitivity
      • OFF = normal sensitivity
    Installation
    1
    Switch on
    Remove the battery-isolation strip to switch on the detector.
    2
    Registering with the app
    Follow the instructions in the app to add the Motion Detector.
    3
    Alternatively: Add the Motion Detector manually
    1. Put Base Station in pairing mode (press Reset/Learn for six seconds until LED flashes blue).
    2. Press and hold LED indicator on detector for three seconds (LED lights up).
    3. Success = one beep from base station. If the detector has not been added within 25 seconds, please repeat the pairing process.
    NOT AVAILABLE
    Tip:
    Give each detector a uniquely name for easy identification.
    4
    Placing/mounting the Motion Detector
    • Mount on flat wall or in corner → widest coverage
    • Keep field of view clear (no curtains, furniture, etc.)
    • Recommended mounting height: 2.4 m
    • Higher mounting = larger pet-immune zone, but bigger blind spot below
    • Choose a location to which animals cannot climb.
    • Do not aim the device at staircases.
    • The objective is that intruders should move sideways across the field of view.
    • Mounting:
      • With screws and wall plugs
      • Alternatively, with double-sided adhesive pads (included)
    NOT AVAILABLE
    Limitations
    • Not for outdoor use
    • Avoid having large obstacles in detection area
    • Avoid direct sunlight
    • Avoid damp or condensatiuon-prone areas
    • Avoid moving objects (e.g., curtains)
    • Avoid reflective surfaces (e.g., mirrors, windows)
    • Do not install near AC/heaters
    • Avoid reflected IR signals (may cause false alarms)
    5
    Testing the Motion Detector
    Test the detector by walking past it. Check whether you receive a notification on your mobile phone.
    Congratulations! The installation of your Motion Detector is complete.
    Setting from device
    Sensitivity / Pet immunity (by internal Jumper setting)
    Button functions
    Test button, Learn button
    Pet immunity
    Up to 25 kilograms
    Sleep timer
    1 minute, extendable up to 3 minutes maximum
    PIR motion sensor
    Range 12 metres
    Horizontal angle
    90°
    Vertical angle
    52°
    Installation height
    2.4 metres
    Power source
    1.5 V, 2 AA alkaline batteries
    Battery life
    3 years (actual battery life may vary depending on settings, the environment and usage)
    Low battery threshold
    2.65 V
    RF frequency
    868 MHz
    Wireless range
    300 metres in open space
    Operating temperature
    −10°C to 45°C (14°F to 113°F)
    Operating humidity
    Up to 85% (non-condensing @ 23°C)
    Dimensions
    75 x 75 x 43.5 mm
    Weight
    77 g (battery excluded)
