  • Rewards Icon
    Photo Motion Detector
    Function overview
    • The Photo Motion Detector is a passive infrared (PIR) motion-sensor camera that sends wireless detection signals and images when movement is detected.
    • Detection range: up to 12 m when mounted at 2.3 – 2.5 m
    • With pet immunity enabled, it ignores pets of up to 25 kg.
    • LED indicator
      • Blue LED ON for 1.5 seconds: Movement is detected and battery is low
      • Slow flash: 30-second warm-up period
      • Continuous flash: Sending images due to a fault (e.g., low battery)
      • Double flash: acknowledgement from Base Station
    • Image capture
      • When armed, sensor captures three alarm images (320 × 184 px) per movement detected.
      • Complex environments with intense light/colours may result in larger file sizes and truncated transmissions.
    • Warm-up period
      When the alarm system is switched to Active mode the Photo Motion Detector will warm up for 30 seconds. During this time, the detector sensor is inactive.
    • Battery
      • Uses 2× 1.5 V “AA” alkaline batteries
      • Low battery → app message + optional push notification, call, SMS, email and the blue LED lights up for 1.5 seconds when motion is detected.
      • Battery replacement:
        • Remove old batteries, wait 10 miuntes then press Function button twice to discharge.
        • Insert new batteries.
        • Plus pole must face upwards.
    • Supervision
      • The Photo Motion Detector regularly sends a self-test signal.
      • If signal not received → “Accessory Failure” in app + optional push notification
    • Pet immunity (JP3)
      • ON = Pet immunity disabled
      • OFF (default) = Pet immunity enabled (ignores pets of up to 25 kg)
    • Sensitivity adjustment (Jumper JP4)
      • ON (default) = increased sensitivity
      • OFF = normal sensitivity
    Installation
    1
    Switch on
    Remove the battery isolation strip to switch on the detector.
    2
    Registering with the app
    Follow the instructions in the app to add the Photo Motion Detector.
    3
    Alternatively: Add the Photo Motion Detector manually
    1. Put base station in pairing mode (press Reset/Learn for six seconds until LED flashes blue).
    2. Press and hold LED indicator on detector for three seconds (LED lights up).
    3. Success = one beep from base station. If the detector has not been added within 25 seconds, please repeat the pairing process.
    NOT AVAILABLE
    Tip:
    Give each detector a unique name for easy identification.
    4
    Placing/mounting the Photo Motion Detector
    • Mount on flat wall or in corner → widest coverage
    • Keep field of view clear (no curtains, furniture, etc.)
    • Recommended mounting height: 2.3–2.5 m
    • Higher mounting = larger pet-immune zone, but bigger blind spot below
    • Choose a location to which animals cannot climb
    • Do not aim the device at staircases
    • The objective is that intruders should move sideways across the field of view.
    • Mounting:
      • With screws and wall plugs
      • Alterntively, with double-sided adhesive pads (included)
    NOT AVAILABLE
    Limitations
    • Not for outdoor use
    • Avoid having large obstacles in detection area
    • Avoid direct sunlight
    • Avoid damp or condensatiuon-prone areas
    • Avoid moving objects (e.g., curtains)
    • Avoid reflective surfaces (e.g., mirrors, windows)
    • Do not install near AC/heaters
    • Avoid reflected IR signals (may cause false alarms)
    5
    Testing the Photo Motion Detector
    Test the detector by walking past it. Check whether you receive a notification on your mobile phone, then view the live image in the Home Security app.
    Congratulations! The installation of your Photo Motion Detector is complete.
    Setting from device
    Sensitivity / Pet immunity (by internal Jumper setting)
    Button functions
    Test button, Learn button
    Pet immunity
    Up to 25 kilograms
    Sleep timer
    1 minute, extendable up to 3 minutes maximum
    PIR Motion sensor
    Range 12 metres
    Horizontal angle
    90°
    Vertical angle
    52°
    Installation height
    2.4 Meter
    Camera lens
    HD CMOS Camera
    Field of view
    (H) 106°
    Resolution
    320 x 240 pixels (1280 x 720, 640 x 480 pixels)
    Night illumination
    Warm white fill light covering 10 metres
    Power source
    1.5 V, AA Alkaline battery x 2
    Battery life
    3 years (Actual battery life may vary depending on settings, environment, and usage)
    Low battery threshold
    2.35 V
    RF frequency
    868 MHz
    Wireless range
    300 metres in open space
    Operating temperature
    −10 °C to 45 °C (14 °F to 113 °F)
    Operating humidity
    Up to 85% non-condensing @ 23 °C
    Dimensions
    95 × 95 × 49.1 mm
    Weight
    125.5 g (battery excluded)
