  • Rewards Icon
    Smart Plug
    Function overview
    • The Smart Plug allows you remotely to switch connected appliances/devices on or off.
    • By integrating it into smart routines, you can conveniently control appliances – enhancing comfort and energy efficiency.
    • Once paired with the base station, the Smart Plug can be controlled remotely or automatically via the app through schedules and smart routines.
    LED indicator overview
    • "ON" after three flashes: Smart Plug is turned on
    • "OFF" after three flashes: Smart Plug is turned off
    • Flashes twice: Switched on
    • Flashes slowly: Pairing/learning mode
    • Flashes three times: Learning successful
    • Brief flash: RF signal transmission
    • Button usage:
      • Press once: Toggle smart plug "ON"/"OFF"
      • Press and hold for three seconds: Pairing/learning mode
      • Press and hold while switching on; release when LED lights up: Factory reset
    Installation
    1
    Plugging in the smart plug
    Plug the Smart Plug into the power socket.
    Plug the appliance into the Smart Plug (appliance must be turned on).
    NOT AVAILABLE
    Maximum load
    • 230 V, max. 3680 W / 16 A
    • If overheating occurs, the Smart Plug cuts power off automatically (LED flashes rapidly) and resumes once temperature drops.
    2
    Registering with the app
    Follow the instructions in the app to add the Smart Plug.
    3
    Alternatively: Add the Smart Plug manually
    1. Put the base station into pairing/learning mode (press Reset/Learn button for six seconds, LED flashes blue).
    2. Press the LED button on the Smart Plug → LED flashes slowly (pairing mode).
    3. Once paired, the LED flashes three times and goes dark.
    4. Check that the Smart Plug works properly in the chosen location.
    NOT AVAILABLE
    Tip
    Give each smart plug a unique name for easy identification.
    Congratulations! The installation of your Smart Plug is complete.
    Power source
    110–230 V AC, 50–60 Hz
    Power consumption
    0.4 W
    Maximum load
    110V: 1760W 16A 230V: 3680W 16A
    Frequency
    868 MHz
    Protocol
    Climax
    Operating temperature
    –10°C to +45°C
    Operating humidity
    85% relative humidity @ 23°C (non-condensing)
    Dimensions
    73.6 × 46.1 × 82 mm
    Weight
    99 g
