  • Rewards Icon
    Smoke Detector
    Function overview
    The Smoke Detector reliably protects against fire hazards.
    With multi-sensor technology, it distinguishes between fast-burning flames and smoldering fires while reducing false alarms caused by cooking smoke.
    • Wireless smoke detector with multi-sensor technology
    • Differentiates everyday smoke from real emergencies
    • Reduces nuisance alarms
    • Alerts with buzzer, LED, and Base Station signal
    • LED indicator
      • Red LED:
        • Quick flash: Alarm triggered
        • Flashes every second: Smoke detector in alarm silence mode
        • Flashes every 2 seconds: Warm-up phase / calibration
        • Flashes every 4 seconds together with orange: Low battery
        • Brief flash: When the Learn/Test button is pressed to check device function or for system pairing
        • 6 brief flashes: Signal is being transmitted
      • Orange LED:
        • Flashes every second: Calibration failed
        • Flashes every 4 seconds together with red: Battery exhausted
        • Flashes every 5 seconds: Smoke detection failed or device malfunction
        • Flashes every 45 seconds: Low battery
      • Test/Learn button:
        • Short press:
          • Send test signal
          • Check smoke chamber
          • Silence alarm (9 min.)
          • Pair with Base Station
        • Press and hold for 10 seconds:
          • Start calibration
    • Battery
      • Uses 3 × CR123 3V lithium batteries
      • Automatic battery check every 25 seconds
      • If battery is low: Orange LED + signal to base station + beep every 45 seconds
      • If battery is exhausted: Red + orange LEDs flash every 4 seconds
      • Replacement: Remove old batteries → wait 10 min → press button twice → insert new batteries
      Note:
      In low battery warning mode, the beep will be silenced for 7 days after the first button press. It cannot be muted again after that.
    • Dust detection
      • The detector regularly checks the optical chamber for excess dust
      • If dust is detected, it reports to the panel with a cleaning request
      • If the chamber isn’t cleaned and too much dust accumulates, a maintenance warning is issued
    • Supervision
      • The Smoke Detector sends periodic supervision signals to the Base Station
      • If no signal is received, the Base Station will indicate a fault
    • Alarm activation
      When smoke is detected, the alarm is triggered, a signal is sent to the base station, and the buzzer sounds.
    • Smoke detection
      • The smoke detector checks air quality every 8 seconds
      • If the smoke level exceeds the threshold, the alarm sounds and remains active until levels drop
      • The red LED flashes rapidly during alarm
    • Alarm silence
      • Pressing the test button during alarm will silence it for 9 minutes
      • The red LED flashes once per second. If smoke falls below threshold during silence, a two-tone beep sounds and normal mode resumes.
      • If smoke rises or exceeds a second threshold, the alarm will sound again and can no longer be silenced by the button.
    • Auto-Calibration
      • After first installation, auto-calibration runs after 4 hours, then every 15 days
      • During calibration, the red LED flashes (every 2 seconds, about 50 sec)
      • If calibration fails, the orange LED flashes every second and a fault is reported. Flashing can be stopped by removing/reinserting the batteries or by starting manual calibration
      • If calibration fails again, the orange LED will flash constantly and continuous beeping occurs—remove batteries briefly and reinsert
      Note: If auto-calibration fails, the alarm uses the last successful value. For best results, calibrate the detector at its permanent location.
    • Recalibration
      • Hold test button 10 sec., release at 2 beeps
      • After 5 sec. beep, calibration starts (red LED flashes every 2 sec.)
      • Lasts ~1 min; retries up to 9 min if fails
      • Success: Two-tone beep, red LED off, normal mode
      • Fail: Continuous beep + orange LED flashes
      • Remove battery → press test button twice → insert battery → restart
    Installation
    1
    Switch on
    • Insert batteries → beep + warm-up (1 min)
    • Automatic calibration (1–9 min)
    • Success: beep + LED off → normal mode
    • Calibration failed: remove batteries, press button 2×, reinsert
    2
    Registering with the App
    Follow the instructions in the app to add the Smoke Detector.
    3
    Alternatively: Add the Smoke Detector manually
    1. Put Base Station in pairing mode (press Reset/Learn 6 s until LED flashes blue)
    2. Press and hold LED Indicator on detector for 3 s (LED lights)
    3. Success = 1 beep from Base Station. If the Detector is not added within 25 seconds, please repeat the pairing process
    NOT AVAILABLE
    Tip:
    Name each detector uniquely for easy identification.
    4
    Placing/Mounting the Smoke Detector
    • Install on ceiling, preferably in room center, at least 60 cm away from walls
    • Avoid: kitchen, near fans, fluorescent lights, AC units, ceiling beams, over cabinets, or attic peaks
    • Recommended locations: open ceiling area with unobstructed view, near entrances
    • Avoid direct sunlight, heat sources, or moving objects
    • Ideal mounting height: about 3 meters; higher can affect detection
    • Use mounting template to mark holes, insert anchors, and screw in bracket
    Congratulations! The installation of your Smoke Detector is complete.
    Important notes
    • Test your Smoke Detector weekly using the test button to ensure it works properly.
    • Clean the detector at least every 6 months: gently vacuum dust from the detection chamber and vents.
    • Wipe the casing with a damp cloth, do not allow water inside. Avoid using cleaning agents.
    • Avoid spraying aerosols such as air fresheners or hairspray near the detector.
    • Never paint or modify the detector.
    • The smoke detector has a maximum lifetime of 10 years. Replace it immediately after this period.
    • A replacement date should be marked on the back of the detector.
    Setting from device
    Alarm silence, manual calibration
    Button functions
    Test / Learn / Silence
    Siren output
    85 dB at 3 m
    Power source
    3x CR123 lithium batteries
    Battery life
    10 years (actual battery life may vary depending on settings, the environment and usage)
    Low battery threshold
    2.7 V
    Frequency
    868 MHz
    Range
    300 metres in open space
    Operating temperature
    –10°C to +45°C
    Operating humidity
    85% relative humidity @ 23°C (non-condensing)
    Dimensions
    106.4 × 106.4 × 45.5 mm
    Weight
    190.5 g (battery excluded)
