  • Rewards Icon
    Solar Panel
    Key features
    The Sunrise Solar Panel (SOL-SR1) is designed to keep your Sunrise Outdoor Camera continuously powered by collecting sunlight. It provides a reliable, eco-friendly power source, reducing the need for manual charging. For best performance, follow the installation and maintenance instructions below:
    • High-efficiency Solar Panel: Converts sunlight into power for your Outdoor Camera.
    • Universal joint: Allows flexible up/down and left/right adjustment for optimal sun exposure.
    • Socket nut: Secures the universal joint to the Solar Panel.
    • Locking screw cap: Fixes the universal joint to the Base.
    • Base and wall anchors: Attach the universal joint to the wall.
    • 3m USB-C cable: Provides flexible placement in relation to the camera.
    Important recommendations
    General
    • Wipe the Solar Panel regularly using a soft, damp cloth to remove dust and debris.
    • Avoid abrasive cleaners that can scratch the panel surface.
    • After storms or snow, ensure the panel is not covered or obstructed.
    • Always ensure the cable remains undamaged and properly connected.
    Location
    • Place the Solar Panel in an area with consistent sunlight throughout the year.
    • The panel needs only a few hours of direct sunlight per day, but more sunlight improves charging performance.
    • Avoid shaded areas caused by roofs, trees, or seasonal sun changes.
    • Weather, season and geographic location affect charging efficiency.
    • The charging cable is 3 metres long, allowing flexible placement relative to the camera.
    Installation
    Have you got everything?
    Before you start the installation check whether your package contains the following items:
    • Solar Panel with 3m USB-C cable attached
    • Universal joint
    • Socket nut
    • Locking screw cap
    • Base
    • 4 screws with 4 wall anchors
    • Quick Start Guide
    Mounting instructions
    1
    Install the mounting base
    • Hold the base against the wall in the desired location.
    • For hard surfaces (brick, concrete):
      • Pre-drill a hole using a 6 mm drill bit, insert a wall anchor, and attach the Base using the provided screws.
    2
    Assemble the universal joint
    • Insert the universal joint into the locking screw cap.
    • Screw the socket nut onto the universal joint.
    • Attach the universal joint to the back of the Solar Panel and tighten firmly.
    3
    Attach to the base
    • Screw the universal joint (with panel attached) into the base by screwing the locking screw cap on top.
    • Ensure the joint is angled upward before tightening. The Solar Panel's tilt angle can be adjusted up to 90°.
    4
    Adjust positioning
    • Loosen the locking screw cap to adjust left/right, then tighten again.
    • Angle the Solar Panel upward by approximately 30°.
    • In the northern hemisphere: point the panel south. In the southern hemisphere: point the panel north.
    • Ensure all locking components are firmly secured after installation.
    5
    Connect to the camera
    • Plug the Solar Panel's cable into the USB-C charging port of the camera.
    • Ensure the cable runs safely along the wall without creating tripping hazards.
    Congratulations! The installation of your Solar Panel complete.
    Safety information
    • The product is only suitable for use in a temperate or subtropical climate.
    • Use the product only at a temperature between -20°C and 40°C and a relative humidity of up to 100%.
    • Use the product in accordance with the installation and product documentation of Sunrise.
    • The product is not suitable for use by children and should not be considered a toy.
    • Do not attempt to dismantle the product as it can be dangerous and contains no parts covered by a warranty.
    Number of cells
    12 solar cells in series
    Mount
    Adjustable swivel
    Contents
    Solar Panel with USB-C cable attached, screws, masonary anchors, swivel
    Wire length
    3m
    Wire type
    13-core durable multi-core cable for power transfer
    Minimum output power (@STC)
    ≥2.8W
    Standard operating voltage (@STC)
    ≥5V
    Standard operating current (@STC)
    ≥570mA
    Dimensions
    120.5 × 173.5 × 12.5 mm
